Home > For Sale & Wanted > [Wanted] Wanted defender Td5 handbrake assembly
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Hi all,
Looking for a good used handbrake assembly…. Anything out there?
Thanks in advance Thumbs Up
Post #929640 13th Nov 2021 7:26pm
If you mean the drum and backplate and internal gubbins, I have about four surplus to requirements. If you mean the handbrake lever, I can't help you.
Which parts do you actually need?
Post #929642 13th Nov 2021 8:17pm
Oldowner
I have a spare lever assembly if needed
Post #929645 13th Nov 2021 8:35pm
amondeggs
Cheers Blackwolf,
Yes it is the back plate, drum and internals that I am looking for please. Basically the whole handbrake assembly apart from cable and lever which I have.
Post #929649 13th Nov 2021 9:32pm
In that case I can definitely help you and will send you a PM.
Post #929654 13th Nov 2021 11:09pm
