Home > Puma (Tdci) > Mass Air Flow Sensor 2.4 Puma.
samstorm
United Kingdom 2009 Defender 90 Puma 2.4 HT Baltic Blue
Hi. I have a 2.4 puma engine and it keeps bringing the the engine light on with a fault code that points to the mass airflow sensor. The air filter is new and the sensor is new but the problem still exists. Any help would be much appreciated. Thanks.
Post #929575 13th Nov 2021 4:34am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Check the wiring going to maf they have a habit of breaking down, you can get new connector from forum shop Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #929579 13th Nov 2021 7:54am
Greyman110
Also if not already done, clean the connection with electrical contact cleaner spray.
Post #929596 13th Nov 2021 10:24am
