Home > Puma (Tdci) > 2.4 2008 Whistling / blowing issue |
Trendkill110 Member Since: 04 Sep 2021 Location: Yorkshire Posts: 73 |
Hello folks.
2008 2.4 110 and an issue has arisen. Figured I'd bang a couple of quick videos on here. First Puma I've owned so worth an ask as possibly a common fault??? Comments welcomed. Thanks in advance 👍🏻 https://youtube.com/shorts/uHowSgJtwRQ?feature=share https://youtube.com/shorts/Sfe5KhUM8Kk?feature=share |
12th Nov 2021 3:57pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 699 |
As already said, most likely to be the manifold to turbo gasket. Take the shield off and have a look for any black soot. Also check the manifold itself as I had a crack in mine with the same results.
If it is the gasket either replace and hope for the best, or take off the turbo and get it skimmed and replace gasket .. or replace the gasket with a Nakatenga one that is designed to deal with any imperfections https://www.4x4overlander.com/product/naka...-gasket-2/ |
13th Nov 2021 8:39am |
Thanks for that guys!
Overlander 4x4 are only 30 minutes drive away from me so heading over there this morning to collect the gasket and stud set. Any ideas of torque settings for the stubs / nuts? Thanks again 👍🏻 Click image to enlarge Click image to enlarge |
15th Nov 2021 8:53am |
Hi
23Nm for the turbo to manifold 45Nm for the turbo to exhaust down pipe/cat |
15th Nov 2021 11:47am |
Gasket and nuts / studs collected.
Heat shield removed. Already looks to have the uprated / thicker gasket fitted. I believe that looks like a cracked manifold! Where can I source a replacement that's been skimmed so I know it's decent and hopefully only have to do this once? Thanks again Click image to enlarge Click image to enlarge |
15th Nov 2021 12:26pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
Two options. Fit new kit and see how it goes. Or remove turbo, and exhaust manifold and get the machined flat. Check for cracks when doing any of it.
15th Nov 2021 1:04pm |
Land Andy -
I think I've found a crack as pictured. Click image to enlarge Does anyone know if the exhaust manifold is the same as fitted to transits? Thanks again 👍🏻 |
15th Nov 2021 1:14pm |
I bought a used transit one off eBay, took off the turbo and got them both machined flat and refitted with a standard gasket. Prior to that I’d been through several gaskets and it was a PITA despite getting pretty quick at changing them.
No issues yet .. 3 years since doing it properly. |
15th Nov 2021 1:17pm |
Yes. I noticed that, and part of the reason I made the comment. Wasn’t sure if was a casting line though. Also the casting of the turbo isn’t great as I’ve previously found out. Click image to enlarge |
15th Nov 2021 1:24pm |
fords part number 6C1Q-9430 for exhaust manifold on 2.4 engine mk7 2006 - 2014 transit
15th Nov 2021 2:03pm |
Has anyone had experience with these?
Click image to enlarge Land Rover are coming in at £330+VAT Ford Parts UK are coming in at £445+VAT |
16th Nov 2021 7:08pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2032 |
Blimey... Ford more expensive than land rover ! the world has gone Topsy-Turvy
16th Nov 2021 8:43pm |
Land Rover Logo
SKULR004489 Genuine OEM LR004489 - LR Manifold - Exhaust (LR004489) part for Defender 2007 >. Authentic LR Part. £758.48 + P&P I say that price is cheep for JLR genuine Manifold - Exhaust Last edited by dorsetsmith on 16th Nov 2021 8:54pm. Edited 2 times in total |
16th Nov 2021 8:49pm |
Not wishing to pee on your parade but check
16th Nov 2021 8:52pm |
