Home > General & Technical (L663) > Maxtrix headlight range in Auto Matrix mode |
Telemarkskier Member Since: 20 Jul 2020 Location: Wiltshire Posts: 129 |
I just thought it was my none matrix signature LED ones that were appalling poor when set in auto mode - high beam. In fact so poor that I had a light bar installed which only illuminates using the old fashioned method (I thought it had been wired so it would work on auto). Still a huge improvement on the Defender headlamp output. 2020 Defender 110 SE 240D: Fuji White.
2011 Freelander 2 SD4 HSE 2007 Freelander2 HSE (man) |
17th Dec 2021 11:55am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 |
Aren’t there different conditions the beams adapt to eg if you go faster or the weather is worse? Mike
17th Dec 2021 8:34pm |
