![]() | Home > Off Topic > saw this and thought it might be of interest! |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1033 ![]() ![]() ![]() |
http://www.lidl.co.uk/cps/rde/xchg/lidl_uk/hs.xsl/index_23989.htm
thay have the attachments too from Thursday ![]() Greg |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
cheers for the heads-up on that on.
i've never had a compressor. pressumably it would be under-power for undoing wheel nuts and the like? |
Get a 75l _ 125l donkey tank with the correct valves and it will do the job for about 1 month
![]() guess i'll stick with the wheel brace and five weetabix in the morning ![]() |
funrover Member Since: 12 Dec 2010 Location: Yorkshire Posts: 130 ![]() ![]() ![]() |
We've got a Wolf version of this compressor and it will do sand-blasting, probably a panel by panel respray and undo your wheel nuts no problem. Editor of FunRover - One blog. Read it! Land Rover rebuild video series here: |
not if Kwik Fit / ATS etc have been near your motor
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 ![]() ![]() ![]() |
Lol, just seen the reply above.....that's what happens when you leave a topic open on your phone then type your reply 2 hours later!
![]() 2011 110 XS DC Stornoway Grey |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
8 Bar is a decent pressure, thats what we have on site from the large compressors, high pressure oxygen is delivered at 15 Bar, Nat Gas at 4 Bar, but its capacity rather than pressure when talking about compressors.
Our oxygen capacity is 1000's of ltrs per min. Capacity is usually meausred in CFM, looks like in this case its measured in litres, having a 24ltr capacity tank, im guessing it would be fine to spray a bumper or a door, but would run out of air if you tried to spray a car. Most tools will state consumption of air. |
it will be fine as a hobby tank the CFM is low so dont expect to much
