Home > Faults & Fixes (L663) > Adaptive speed limiter
mse
Can someone explain how this system works on their defender as I think I'm going to go insane, it's not like this on any other LR we have
Do you have to enable it on this menu every session eg every time to start the car?
 Mike
Post #927984 31st Oct 2021 6:01pm
mse
Anyone before the dreaded trip back to the dealer, to be told that’s how it works Mike
Post #928307 2nd Nov 2021 10:35pm
zilch
Australia
If you are enabling in the Pivi menu then it should be a "saved" option. Ours is disabled due
to the inherent number of School Zone time of day restrictions and "advised limits" for
bends and such like.. it has always remained "off" so assume if you set it to on, it should
stay that way when you start the vehicle. yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #928314 3rd Nov 2021 12:01am
mse
Thanks thats helpful and exactly how the disco works, except the disco, once enabled on Privi you actually cycle through adaptive cruise, adaptive speed and normal speed limiter...but same principle.
The dealer say you had to enable it each time...but i could tell the service guy was trying to fob me off - thats what they are trained for, hence checking this time before i go back
thanks Thumbs Up Mike
Post #928442 4th Nov 2021 7:50am
TRGRichie
Sounds like by pressing the can button for 3 seconds it will select adaptive speed limiter?
 L663 90ht
Post #928463 4th Nov 2021 10:02am
mse
Yes this is sort of my problem, i first have to enable it from the privi menu to then do that...have i pressed the button long enough, its a good question, ill try that again Thumbs Up Mike
Post #928473 4th Nov 2021 10:50am
martinf
It only works if the traffic sign recognition system is operating. Have you checked that it is switched on?
Post #928478 4th Nov 2021 11:48am
martinf
Here are the relevant pages from the Handbook which may help
Post #928479 4th Nov 2021 12:02pm
mse
Thanks all
when enabled it works (although the traffic sign is a good point), but the steering wheel button does not turn it on unless ive gone into the privi setting menu first, thats then required each time i restart the car
I have got to try the 3 second press as suggested
On the discovery you enable on the privi menu once in the vehicle life then its set and never go in again
if that makes sense Mike
Post #928484 4th Nov 2021 1:17pm
Gareth
You won’t keep it on for long! Mine slows me down to 20mph when passing junctions, if the sign is visible from the main road. Dangerous IMO. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #928513 4th Nov 2021 4:46pm
mse
Admittedly i use adaptive cruise more, but speed limiter i use it all the time, it works now - i just have to go through 3 or 4 steps to get it on for the journey.
When working its great, the only issue i have had was not detecting the smart motorway, so not dropping my speed.
Just for information, if you push the accelerator to the floor it will auto over-ride the speed Mike
Post #928574 5th Nov 2021 12:35am
mse
Took it for a spin today and the only way to get it on was to go into the master privi menu and turn Adaptive on, then the steering wheel button turned it on, otherwise its just toggling between cruise and normal speed limited.
They will have to have it back for another time Mike
Post #928774 6th Nov 2021 1:00pm
TRGRichie
Even with the long 3 second press? L663 90ht
Post #928794 6th Nov 2021 4:11pm
mse
Yes, just toggles between cruise and normal limiter, until you enable it in the menu each drive.
Not like the disco that then allows you to go between each option Mike
Post #928811 6th Nov 2021 6:01pm
Loafer
Just tried this on a journey and got it to work…
Click + to set a speed and then the top right button to toggle from Limiter to Cruise.
Then, to move from fixed cruise into adaptive cruise, press and hold the gap adjuster button. Carpathian Grey 110 D300 HSE
Post #928832 6th Nov 2021 9:18pm
