Home > In Car Electronics > courtesy light
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
courtesy light
I've got no interior courtesy lights working on the recently aquired 50th. There's no alarm on Japanese 50th but I think the 10as green box is behind instrument binacle. Ive taken out the front light and established I've got 12v to the purple/white wire and earth but nothing to purple wire and earth. Plugging switch back in I've nothing across the bulb.
Any help appreciated as both front and rear aren't working.
Post #926960 24th Oct 2021 3:38pm
Ianh
FYI.
The 10AS or ALM module can be seen if you remove the drivers footwell speaker and look upwards. Green if 10 AS, black if ALM.
https://blackbox-solutions.com/help/SM031.html
Post #926965 24th Oct 2021 4:29pm
Dinnu
Would it still be visible with the ac unit? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926966 24th Oct 2021 4:32pm
Dinnu
Re: courtesy light
I am not familiar with 1998 era models.. but later models, the Purple/White is coming from the 10AS, and the solid Purple is fused directly from the battery. Earth is going to a ground, somewhere.
You say "got 12v to the purple/white wire and earth"... given that you have 12V on the earth black wire, then you have a broken earth. You should measure 0V on the black wire (so you actually get 12V across the bulb. Perhaps you can test a piece of extra wire, connect it on black and ground it somwhere. By the sound of it, that should power up the interior light when any door is open or you unlock the Defender.
The solid Purple wire should always have 12V on it.. so that you can switch on the interior light anytime you wish. This should be fused, check the fuses on the transmission tunnel. Sorry, I do not know which one would that be, but usually there is a label, and should indicate which one is for the interior light.
Hope this helps somehow. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926968 24th Oct 2021 4:43pm
ginjez
ok, I miay not have explained correctly. To simplify I have got 12v to purple/white. Anyone know which fuse it is to interior light. I'm not the best at Japanese Laughing
Post #926973 24th Oct 2021 4:54pm
dorsetsmith
fuse 30 main fuse box or ヒューズ30メインヒューズボックス
Post #926987 24th Oct 2021 6:08pm
Dinnu
Can perhaps look for this symbol?
Post #926996 24th Oct 2021 7:03pm
Procta
Re: courtesy light
check the connector in the roof headlining, it will be a little further back from the light somewhere, its like a five pin connector. ( that also bridges the rear light i believe) That could be rotten, It happened on my 300 Tdi, we could not work out why we were getting power to the driver side window screen post, but not further up to the light. after i had a feel around, i found a connector that was rotten, We cut the connector off, ( not really my idea) My dad made another loom up and it was working.
So it may need a bit of a clean, i think you can get a replacement loom too. I have a spare rear one in storage Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #927763 30th Oct 2021 1:18am
