Home > Maintenance & Modifications > IRB Developments - Defender High Performance Air Box
JOW240725
I thought this looked very interesting. I'm sold on the idea the air intake is restrictive but never been entirely happy about carrying out the air box mod where you cut out the water catcher thingy. This may be the answer. No ideas on cost yet.
From IRB Facebook page....
"At long last - New Product Time:
Defender Puma High Performance Air Box
On the back of the air box design for the IRB Coyote V8 Conversion, we decided to take a modular approach and make a lid to suit 2.2 and 2.4 Tdci Defender (we can also do lids for LS3 and other engine options).
The standard Puma Air Intake/Air Path is massively restrictive and at times is down to an orifice that is less than 23mm wide by 90mm high - as well as being a far from perfect flow path (and not sealed).
With the new set up, the air box is fed via a 102mm pipe (made in an OEM style) from a correctly profiled air intake into a custom ITG filter.
The intake and the air box both feature water traps/drains and fit into existing mounts/holes (RHD only).
With the air box tucked under the wing, access to the intercooler hoses, steering box and air filter is hugely improved.
Road and Rolling Road testing coming soon - including back to back results.
Thanks to @blackbirdindustriesuk for their excellent 3D scanning, CAD and fabrication skills, turning my ideas into a repeatable reality!
#irbdevelopments #defendersve #pumaperformance #makingdefendersbetter"
 James
Instagram @suffolk_rovers
Post #926611 21st Oct 2021 7:12am
It's an interesting idea but I wouldn't like to have to rely on a custom air filter. Service items like that really should be off-the-shelf parts, IMHO. I believe that the Nugget Stuff offering uses a commercial air filter. Darren
Post #926619 21st Oct 2021 8:30am
donmacn
I spoke to IRB months ago, and at that time he said he was working on something like this for the 300Tdi.
I’ve kept checking the website, but nothing so far. This looks like a positive development and offers some hope that a Tdi version might be in the wings (pardon the pun!) Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #926625 21st Oct 2021 8:54am
Bluest
Yes it's an old Nissan light truck/car filter. You can get them from any filter supplier by part number cross reference. The only slight question mark I have is that the engines it is intended for are less powerful than the Puma so I worry slightly about weather it flows enough air. In practice I haven't seen a problem, but it bugs me sometimes it isn't bigger. 2007 110 TDCi Station Wagon XS
Post #926636 21st Oct 2021 9:27am
Porny
Site Sponsor
The 300Tdi actually uses some of the same parts... and is progressing. Air box version 2 is being made as we speak - and it uses the same OEM style pipework.
With regards to filter options for the Puma Box - whilst I'd happily use on off the shelf filter, to make use of the space there was nothing commercially available IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #926702 21st Oct 2021 5:46pm
Co1
When are you doing the performance tests Porny, and what do you expect it to retail at?
Col
Post #926706 21st Oct 2021 6:26pm
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Sounds interesting.
Post #926719 21st Oct 2021 7:33pm
donmacn
That’s what I was hoping for, thanks for confirming. Looking forward to it. I’ll keep my eyes peeled. Donald
in the past..
Post #926721 21st Oct 2021 7:44pm
Porny
Site Sponsor
Col
Will be on the dyno as soon as I have time - the Defender 90 with the first production intent Air Box is having quite a few changes, but air box will be run on a standard Defender as well.
Prices - will be confirmed ASAP. I can't deny its not going to be cheapest thing in the world due to the fabrication involved. IRB
Post #926827 22nd Oct 2021 11:58pm
Naks
following with much interest Thumbs Up --
Post #926845 23rd Oct 2021 9:26am
Ianh
Any updates on this development Porny ?
I’m looking to improve the air flow into the turbo so intrigued by your innovative solution. I’m not fitting a RAI so the water drain facility on yours appeals as well.
At present I’ve looked at.
1.Nakatanenga air intake on top of the wing with steel snow cowl
2.Nugget stuff air intake on std wing position.
3 Modifying the standard air box
4.Nugget stuff air box with either nugget stuff or Nakatanenga intake.
But before deciding I would like to know more on your solution.
Post #943976 27th Feb 2022 2:35am
ChrisCSL
I'm with Ian in showing interest.
I already modified the original puma airbox which was a faff but di make an improvement. I'm still running the original small pipework though.
I know Porny's a busy man but it would be good to get an update
Post #944128 28th Feb 2022 4:42pm
Sulisuli
I am certainly interested too, having seen the first 3D printed prototype inside wing attachment that was supplied to trial by Roy5695 from Porny. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #944133 28th Feb 2022 5:37pm
X4SKP
It's an interesting idea but I wouldn't like to have to rely on a custom air filter. Service items like that really should be off-the-shelf parts...
Has anyone 'successfully' modified / tested a standard Airbox to improve it... Question
This may be a DIY take on job retaining use of the standard LR Filter.
I've been looking at this too...
Is the Nugget Stuff offer the 'best' currently, with standard filter replacements... Question SKIP
Post #944143 28th Feb 2022 6:21pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Sounds interesting. Please keep us posted.
Post #944157 28th Feb 2022 7:29pm
