![]() | Home > Tdi > 200tdi Clutch Failing? |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 828 ![]() ![]() ![]() |
Juddering and slipping easily with little pedal pressure could be due to contamination maybe an oil leak into the bell housing. Is the wading plug fitted, is there any oil leaking from the drain hole?
Disregard the clutch age/milage despite a new clutch being fitted previously. There are clutches and proper clutches The one fitted could be cheap junk or badly installed and you might have been lucky to get 30k. |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 947 ![]() ![]() |
Good point. I shall have a look in the morning.
If it does end up having it replaced, it is booked to have LOF PowerSpec one. |
Never felt the need or justification for fitting a HD or 'performance' clutch to a stock vehicle despite enthusiastic driving on and off road. A good quality standard spec unit has always proven more than adequate and never left me thinking it needs improvement.
