Home > Maintenance & Modifications > Rear NAS Bumper - Rusty water
mlightfoot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Wonder if anyone can help me, I recently bought a genuine LR rear NAS bumper for my Puma 90 xs. Fitted fine, but after rain etc I have noticed I get loads of rusty coloured water all down the rear mud flaps and brackets!?!?
Anyone experienced this or how to deal with it?
I also have some rust bits appearing on the welded joints of the bumper, but thought it was powder-coated!?!?
Post #6265 13th Jan 2009 4:08pm
Grockle
I would take it back to the dealer,doesn't sound good not at the price they charge. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #6266 13th Jan 2009 4:52pm
mse
It isnt powder coated inside the tube.
I have one and mine doesnt do this. I did do a lot of waxoyling when fitting it.
Is it a genuine bought from a main dealer as you could take it back? they have 12month warranty.
Just out of interest, did you reuse the crossmember trox bolts?
Oh and did you check the finish - all the ones ive seen (5 now) have some damage to the finish from shipping - you need to fix this before fitting. Mike
Post #6267 13th Jan 2009 4:56pm
beetroot
Mine does it too, you can take it back to the main dealer and swap it, but the new one will do the same, i have just taken mine off (again) and put some black silicone sealant around the holes, thought it was worth a try!
Post #6296 14th Jan 2009 4:36pm
mse
The other thing i do with ALL external parts im fitting is waxoyl surfaces touching - so around the tubes the washer plate ans chassis all have waxoyl on each side. Mike
Post #6297 14th Jan 2009 4:54pm
mlightfoot
Took it into the dealer, apparently a known issue, they have replaced it and driving in the pouring rain today and no rusty water Very Happy
Post #9037 25th Mar 2009 9:26pm
Ferrett
Jersey 2001 Defender 90 Td5 SW Alpine White
In the process of removing a NAS Bumper/Step from the rear of my 2001 TD5. Only just acquired the vehicle so not sure on the age of the NAS or how its been treated, however, badly rusted on most surfaces and the rear cross-member is badly pitted in a line that follows the top of the NAS with a 10mm perforation just about where your left foot hits when getting in the back. Bolts are difficult to remove but have used plenty WD40 and they are moving, still plenty galvanizing on the bolts.
Once the cross-member is repaired, painted and waxoyled then going back to a fold up step and drop plate tow bar arrangement.
Will take a couple of photos and post tomorrow. 2006 D3 Man TDV6 SE - Buckingham Blue
2001 Defender 90 TD5 SW - White
Post #9038 25th Mar 2009 9:45pm
