Home > Technical > Defender engine for 2003 TD5 and 2014/16 tdci
roche1800
Please can I ask for advice on engine oil, it is my understanding the preferred grade for both TD5 and ddci is 5w-30.
What I would like to know is if 10w-30 was used in both would it have any long term impact?
Post #924990 8th Oct 2021 12:55pm
Dinnu
For 2014/16, 2.2 engine, oil needs to be low ash, due to the dpg. oil spec advised on this thread:
https://www.defender2.net/forum/topic34176.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #925008 8th Oct 2021 4:10pm
Ianh
As above you need specialised low SAPs oil for the the 2.2 TDCI from MY2012 due to the DPF being fitted.
I use Millers XF Longlife C1, it performs well and if you do a search on line you can get it at a reasonable price. If doing oil changes I would recommend genuine LR oil filters as well.
Post #925011 8th Oct 2021 4:30pm
Dinnu
F and G are too close to each other Embarassed
DPF I meant.
+1 on Millers. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #925023 8th Oct 2021 5:56pm
