Home > Maintenance & Modifications > Defender XS seats
karlp606
United Kingdom 1997 Defender 90 300 Tdi CSW Firenze Red
Defender XS seats
So I have some Defender XS leather seats I have hopefully secured!!
I am presuming they are a straight fit usual 4 bolts - with regards to the heated side of things they will just have a plug connector - can I then strip the plug - wire into live feed/relay, add switches into the dash (or seat box I was thinking) - bobs your uncle Fannys your aunt..
Has anyone fitted XS seats into a 200 or 300 before?
Post #924291 3rd Oct 2021 8:32pm
Dinnu
Keep in mind, especially with the seat base, that you have to be able to remove it without cutting the wires... so a connector is needed. By default, seat base and seat back have 2 different connectors, but T connected.
Check the power (current) draw, so to make sure that the connector can easily handle it without melting.
I buy in bulk 2 pin connectors (made in China as most other stuff is), but have been pleased with them. However highest power I connect is 25W, which is roughly 2A. But you will need a dedicated crimper, that folds and crimps the pin on the wire (and insulation for anchoring).
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #924306 4th Oct 2021 6:05am
karlp606
Dinnu as usual you legend Smile
Post #924349 4th Oct 2021 9:22am
MGCarr
United Kingdom 1997 Defender 90 300 Tdi PU Rioja Red
I have fitted heated cloth XS seats to my 300tdi 90, l find them more comfortable if mounted on Mud seat rails. The incoming wiring goes to the seat back and a wire comes out from the back to go to a plug on the seat base - see pic
Sorry not the best pic.
The only downside I find is that you can’t fit the original centre seat at the same time.
Post #924478 4th Oct 2021 7:36pm
karlp606
Thanks for that I've got a cubby so should be okay with that.
Post #924479 4th Oct 2021 7:38pm
L110CDL
I have the half leather XS seats in Millie and all wired in and you can fit the middle seat in between them
Wink Clayton.
Keeper.
Post #924660 5th Oct 2021 9:12pm
Profyaffle
I like the idea of a cubby but the middle seat just looks so nice and comes in handy on occasion.. Thumbs Up 1993 200Tdi Defender 90
Post #924695 6th Oct 2021 8:50am
