Home > Technical > Spot welds |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
Once the material has been drilled out it obviously can’t be re-spot welded, so you’d be looking at having each spot puddle-welded with an AC/DC tig welder.
Definitely not impossible, just not that many people around who have the kit. It’s the route I would take - LSL on the Fylde Coast could do it but I’m not sure who else does TIG. To buy the kit would be about £1000 - I’m saving for one now. The far easier alternative (and arguably stronger) is to use panel bond adhesive with or without rivets. As you suggest pop or (if you can be bothered) solid, countersunk, aircraft rivets. Here’s a video. |
26th Sep 2021 12:09pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 634 |
I have £5k of AC/DC tig welder and the know how to use it properly but I don’t use it to fix new panels. If you are replacing with new panels then best way is to drill out all old spot welds, clean the flange up and use Soudal Carbond to bond the new panel. Countersunk rivets can be used where they are hidden by cappings to provide a mechanical fixing.
I use the tig for welding up corrosion holes (usually holes in rear tub side panel from lower stay) or welding up holes drilled for chequerplate. |
26th Sep 2021 2:06pm |
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 101 |
Thanks guys, I was thinking sealant and rivets is the way to go
27th Sep 2021 6:51am |
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 151 |
I went old school aircraft rivets when I did mine... Mostly cos I'm old
Click image to enlarge Cheers Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
27th Sep 2021 7:59am |
