Home > General & Technical (L663) > Testing the maximum side slope angle. |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3372 |
13th Sep 2021 12:49pm |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3498 |
Ran out of talent š
I wouldnāt think the insurer would pay out if this video was found by the underwriter. |
13th Sep 2021 12:58pm |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
Looks like its China - a little filler and few rattle can and the rest will buff out in the local body shop...
13th Sep 2021 1:44pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1316 |
Must have overloaded the noodles in the side storage locker.
13th Sep 2021 3:40pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2634 |
On a positive noteā¦ā¦ā¦damn, that underside is cleanā¦..
13th Sep 2021 4:32pm |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 777 |
Car feeling sleepyā¦ā¦.. Car lay down for little sleepā¦ā¦..š“š“š“š“š“
13th Sep 2021 5:06pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
Pretty sure that will be a write-off, all the o/s panels dinged and at the very least the side curtain airbags deployed. If not a write-off it will be a very expensive repair, what a !
At least the hazard lights came on automatically to keep everyone safe (another utterly pointless feature of modern cars - it would be more sensible if the battery auto-disconnected in an accident). I presume that it isn't possible to switch off all these systems (airbags etc) when you don't want them on? Ironic that the car is clever enough to turn the hazards on, but not clever enough just to stop when it is about to fall over. |
13th Sep 2021 5:13pm |
Loafer Member Since: 29 Jun 2021 Location: Kent Posts: 25 |
The point of the hazards is to alert people coming up on a crash, so they donāt crash into you and create a pileup.
Equally, if you crash off the road, hazards help draw attention to the wreckā¦you will have seen that recent horrific case where people died after being in the wreck of their car for several days. Carpathian Grey 110 D300 HSE |
13th Sep 2021 5:22pm |
Philip Member Since: 09 Mar 2018 Location: England Posts: 510 |
Pretty sure most modern cars have some sort of battery disconnect system in the event of a crash (pyrofuse or otherwise).
Do you really want the airbags not to work when you turn your car over? |
13th Sep 2021 5:27pm |
My money says it will be a write-off as well. Suspect unless it was smart enough to shut down the engine, there will be all sorts of issues with oil starvation and excess oil getting thrashed about under the piston skirts.
13th Sep 2021 5:39pm |
Smart? JLR probably knew it had rolled before the driver
13th Sep 2021 5:51pm |
Under some circumstances, absolutely, you bet I do. I've not come across anything as sophisticated as a pyrofuse on a light vehicle yet, and a megafuse is likely to be very little use. You can weld without blowing a megafuse, so setting a vehicle on fire without blowing the fuse is easy. |
13th Sep 2021 6:30pm |
I suspect that (like rear fog lights) this is an idea which someone thinks is good and which has absolutely no real world supporting evidence. If you need the hazards on to avoid an inverted car in the road, you shouldn't be driving. Then again, as so many of the people on the roads today clearly shouldn't be driving, perhaps it is a good idea. |
13th Sep 2021 6:35pm |
If youāre wearing a seatbelt, I canāt think of a situation. As above, lots of cars have had battery safety disconnects for years, pyrofuse or otherwise. Iāve just spent ~Ā£400 swapping the explosive ābattery safety terminalā and harness on an old BMW. |
13th Sep 2021 6:52pm |
