Home > Puma (Tdci) > Turns over but not firing
Greyman110
So recently had the head gasket changed and noticed that the car wouldn't fire up on the first turn like it used to.
Took it in and had the deisel return pipe replaced but I still have an issue.
It will be going back to the garage but in the meantime does anyone have any idea what can casue this?
I'm hoping it might be something I can just quickly do myself lol.
Post #921003 11th Sep 2021 9:59am
dorsetsmith
to start with 2.4 or 2.2 ?
can you read DTC ? do you have access to Namco to plug in and read DT codes
live date from ECU on start up i.e. fuel presser
Post #921006 11th Sep 2021 10:26am
Greyman110
It’s the 2.4
I have an ultra gauge wired in but do also have a nanocom.
I’ll have a look at the fuel pressure numbers when I get back.
Post #921009 11th Sep 2021 10:38am
dorsetsmith
ok
Post #921013 11th Sep 2021 11:08am
Greyman110
So after leaving the car for a few hours it fired up on the second turn.
After turning it off it wouldn’t fire again. Here’s a vid of the nanocom stats
https://streamable.com/yv2cyw
I did have this fault code:
Post #921032 11th Sep 2021 2:37pm
Greyman110
And now it just fires up first time!
Fuel rail pressure is running at 22.12-24.25
Fuel rail sensor is 23.87
Fuel required is 124-127 but dropping as it’s ticking over
Quick scan shows the same fault code as above.
Cleared and scanned and no faults.
My battery seems to be running at 14.00 - 14.50v which seems high?
Post #921034 11th Sep 2021 2:50pm
dorsetsmith
Fuel rail pressure is ok at start up
are reading engine rpm then starting ? if not check CKP crank position sensor left hand side engine flywheel end i.e. driver side
Is that DTC U0100 appearing again ? loss comm on the CAM to the ecm - abs - ins panel check wiring and instrument plugs have been common problem point
Post #921043 11th Sep 2021 3:55pm
Greyman110
Thanks dorsetsmith
I did a cold start this morning and it fired up immediately. Left to run, turned off and started again and it fired up on the button.
Scanned for faults and it’s all clear.
Have now started it about 7 times and it’s fired first time every time.
RPM gets to about 180 then it fires.
So now I’m at a loss as it seems fine. I’ll take it for a drive and get it up to temp and see what happens.
Post #921150 12th Sep 2021 11:26am
dorsetsmith
camshaft position sensor CMP will stop engine from starting if is failed with dtc, but if fails when engine running ecu go to default set point with DTC
intermittent faults are Censored
Post #921163 12th Sep 2021 1:53pm
Greyman110
@dorsetsmith You’re absolutely right! What a Censored
Took it out today to test and the issue seems to come up when the engine is up to temp.
Started first time from cold. Got it up to temp, turned off and waited a min before starting and it just turned over. Tried a few more times and it did fire up. Started a few more times but only after several goes each time.
So warm engine = trouble firing up.
Oh and no faults when scanned.
Bearing in mind that this issue only started after the head gasket was replaced. I just have no idea Big Cry
Post #921281 13th Sep 2021 2:13pm
Greyman110
Could it be air in the fuel system?
Post #921523 14th Sep 2021 9:29pm
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
Hey Greyman
I had starting issues after replacing my head gasket, I couldn't fire up at all.
In the end it was a faulty Crankshaft sensor even though it was a new one.
I would try to replace this and maybe also the camshaft sensor.
They are not expensive and you can keep them as spares if they don't solve the issue.
Good luck
Kev
Post #921542 15th Sep 2021 6:00am
Greyman110
Seems like that’s the general consensus so I’ll pick one up and see what happens.
Post #921680 16th Sep 2021 7:17am
Greyman110
So I replaced the cam sensor (the one at the top on the near side) took the car for a drive up to temp. Turned it off and tried to start it again.
It took longer to turn over (about 3 seconds) but it fired up. Tried it a few times and it was generally the same each time. From cold start it fires in 1 second.
Does this sensor work in conjunction with the crank sensor? Should I replace both or would it not make any difference?
It’s certainly not fixed but does seem slightly better.
Post #922103 20th Sep 2021 3:27pm
Cam sensor is used in conjunction with the crankshaft position sensor, but the cam sensor is only used during startup when it allows the ECM to determine which stroke the engine is on, it being a four-stroke engine of course.
Post #922104 20th Sep 2021 3:36pm
