Home > In Car Electronics > Blank canvass - Alarm/Immobiliser/Tracker + central locking
KylieTheOneTen
United Kingdom 1988 Defender 110 V8 Petrol CSW Arles Blue
My truck (110 CSW 1988) is undergoing a full nut and bolt restoration and we are getting to the electrics/electronics. If you had a blank canvass and wanted to fit central locking intergrating with an alarm/immobiliser/tracker (all Thatcham approved) and you weren't too worried about cost what direction would you go down?
Post #920852 10th Sep 2021 12:39pm
KylieTheOneTen
Anybody got any advice??
Post #921248 13th Sep 2021 8:03am
karlp606
United Kingdom 1997 Defender 90 300 Tdi CSW Firenze Red
Central locking is quite easy to install - there is a good UK Supplier call HAWK - they sell kits - alarm/central locking/immbollisers all in one kit.
Theres a few walkthrough guides installing these on defenders also.
Usually a 2 hour job for someone with good car electric knowledge.
If you want the rear door to be on the CL usually a bit harder to run the cables etc and fit the actuator with the way the defender rear door locking units work but it is doable.
Check here;
https://forums.lr4x4.com/topic/32024-fitti...fender-90/
https://www.ebay.co.uk/itm/233716715137
Post #921250 13th Sep 2021 8:49am
KylieTheOneTen
Thanks Karl - appreciate you taking time out. It is reassuring to know that Hawk is the option you identified as it is one I have been investigating. Once the CL has been fitted is there a particular brand of alarm/immobiliser/tracker you'd recommend. I have been reading up on Scorpion - do you have an opinion on them?
Post #921251 13th Sep 2021 8:52am
karlp606
No worries.
I went with a Hawk alarm that has a loiter feature so if the alarm is set and someone is hanging about around your car it will sound a mini alarm before the full alarm actuates.
Alarms and Immoblisier are only deterents and usually easy to get round for certain crims.
Long as its loud as f*ck lol
Get a pedal guard or a pedal pin for extra secruity.
Post #921252 13th Sep 2021 8:55am
Jizzer
Ireland 2004 Defender 110 Td5 USW Bonatti Grey
Check here;
hi karl could you point me in the direction of one of these walkthroughs just got a 110 td5 and need to secure it
Post #932786 7th Dec 2021 8:53pm
Likeomg
Having 4 different trackers on my current cars, Vodafone / cobra track for me is the best.
Post #932789 7th Dec 2021 9:38pm
kmac
Hi can you please elaborate on why Vodaphone/Cobra track is best?
Post #933030 9th Dec 2021 9:47pm
