Home > In Car Electronics > Another morning drive another issue |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1850 |
To be honest I don't think that indicator thing is what you need. On the underside of your boss will be two holes, directly opposite each other. They are for the pins that then engage with the blue plastic indicator cancelling ring on your column. If you haven't got the pins, or if they are too short, you could just get some long bolts M5 or maybe M4, cut the heads off them and either tap the boss and thread them in, or glue/resin them in. Basically you need to fit two pins to your boss to activate the cancelling ring that's already there. I thought I'd taken photos of this in the past, but if I have, I can't find them. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
11th Sep 2021 4:26pm |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 298 |
On the question of the little brass inserts on the back of the stalks where the plastic melts, is there anyway to slightly move this in any direction so you get the connection for the dipped beam to come on? I presume the connection is on the main headlight stalk also that controls the flash/fog etc. |
12th Sep 2021 7:35am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1438 |
I don't think there is a safe, reliable way to repair a light switch that has melted.
If you need a temporary emergency connection then to get you home, it is possible to bypass the side light/dipped switch. Join all 3 terminals in the harness socket that the switch plugs into. This will turn the sidelights and dipped on all of the time. Main beam should then function as normal from the other stalk. I worked this out at the roadside one wet, dark night, using odd bits of wire and insulating tape. After I fitted a new switch, I cut the plug and wires from the old switch and crimped the wires together. I now keep this in the cubby box.just incase the new switch melts again. Remove the cowl, unplug melted switch, plug in joined wires, and away you go. Click image to enlarge Edit, Having reread the earlier posts, I'm not sure which switch you have the problem with. Bypassing the main beam switch using a similar method should be possible, but don't wire it to have both dipped and main on at the same time !!! |
12th Sep 2021 11:55am |
Used the car today and lights all good
Seems to be when its warmer weather the lights aren't working - suppose this could from something swelling in the heat and causing the non connection. Further investigation required! Ordered the indicator cancel ring so will see how this fits with the mountney boss. |
12th Sep 2021 6:25pm |
