![]() | Home > Wheels & Tyres > Anyone fit 10 x 16 et -32 Modular wheels on a 90 |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 721 ![]() ![]() ![]() |
My 90 has 285 75 r16 tyres on 16 x 8 -32 wheels and roughly a 2 inch lift if that helps as a guide? To be honest it needs wider arches as it throws muck up the side which fills the door locks with crud and covers the mirrors in rain water but it's off the road at the moment. The suspension uses the Gwyn Lewis setup and no adverse effects on how it drives, it corners well and has plenty of suspension flex offroad.
I think you might find that 10 inch wheels are a bit on the wide side for 285 tyres though? ![]() Click image to enlarge 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
lamakdaddy Member Since: 24 May 2020 Location: uae Posts: 3 ![]() |
![]() Click image to enlarge Thanks! Your wheels look great! Look bigger than 8inch. I already have the wide arches . |
![]() Click image to enlarge ![]() Click image to enlarge Well they are on and what an improvement to the looks . Have yet to drive her but pleased so far.. |
Maurits Member Since: 04 Nov 2021 Location: Gent Posts: 3 ![]() ![]() ![]() |
these look great! what offset did you end up using?
