Home > Modifications & Maintenance (L663) > Onboard air Mod , Viair 485c + 2 gallon tank - ext.output
Defendit..
Netherlands
Installed my Viair 485c aircompressor and 2 gallon tank in de back of the 90 ( Hardtop, Van, Commercial)
Used Flexilla 300psi hoses, professional crimped.
Did use a max 15 bar regulator between.
Made an external safety Quick coupler on de back.
Regulator set to 11.5 bar.
Compressor stops at 14 bar /200 psi, starts again when it drops under 165 psi
Carling HR switch dtdp, 40amp fuse, Direct to battery
Hose thru the rear vents, with a 90 degree fitting for connecting the safety coupler
Prevost S1 euro safety coupler ( max 12 bar)
When Offroad and going back to the road I can fill my airtank in advance,
So with aired down tires of 20 Psi refill of 4 tires to 34 Psi take just 5 minutes. No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #918739 25th Aug 2021 10:44pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
That looks like a great solution and probably cheaper than the built in one Land Rover offers Bow down Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #918824 26th Aug 2021 6:14pm
