Home > Pictures & Video > New Defenders having a nice drive. |
Fair play, Tim. At what point will you decide that your old 90 is truly obsolete? Darren
24th Aug 2021 8:30pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
I don’t think it will ever be totally obsolete as it will always give somebody else some off-road fun. My 90 has done less than 1000 miles in the last year and most of that was runs to town just to keep the oily bits exercised. It went into the local garage last Wednesday for MOT and to get a few bits that are starting to show wear and rust has got a bit far on them replaced so it’s cost per mile just went through the roof. It will be a hard move to sell it after I’ve owned it for 20 years in October. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
24th Aug 2021 8:51pm |
Heh, heh, I did mean obsolete to you as you're clearly using your new Defender to the full Darren
24th Aug 2021 9:00pm |
Incidentally, it was interesting to see just how much of a difference the locking rear diff made when climbing that step. My impression of the new Defender is that it relies much more on it's traction control to keep moving than axle articulation keeping the wheels on the ground and so, relative to older vehicles, the rear locker makes much more of an impact. Darren
24th Aug 2021 9:05pm |
I suppose that’s the compromise you have to make to have the superb comfort from the independent air bag suspension over wheel articulation. The ride comfort on rough surfaces is fantastic compared to my 90 - I cannot understand the comments made by some of “professional” testers and journalists that at off-road height the suspension is too hard - I suspect many of them have no experience of the old Defender on very rough surfaces. Why should we travel in discomfort in the 21st century even if it means having to use traction control to prevent wheel slippage when contact with the ground is lost. In the section where we drove down the rocky bit on Grizedale I went down using the HDC on its lowest 2mph setting, you can see what happened in the black SE when the driver didn’t set the HDC right down to minimum, the car went down rather quickly! On some of those trails I would have had big problems with cross axle situations too in my non Traction Control fitted 1996 90, one if the later TC equipped old Defenders would probably be as good as ND in that situation. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
24th Aug 2021 9:48pm |
