- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
BIMbound
Short somewhere from under dash fuse nix | |
Hi. Struggling this weekend post new radio install which had gone really well……
Whilst testing stereo turned lights on in order to see why new led dash lights weren’t all on, started England at some point noticed no side lights on RH.
10A F19 blown.
Go on to find out that just about everything is shorted to earth. Fault traced so far by elimination to
60A Fusible link to under dash fuse box
15 & 20 amp fuses for Alarm (all intact). With these removed it’s only the under dash fuse box which is shorted.
New head unit removed and all connections double checked as was new Optimil revers cam/number plate light
Any pointers grateful accepted!
Thanks in anticipation….
22nd Aug 2021 1:45pm |
BIMbound
Inexplicable autocorrect typo in the subject
22nd Aug 2021 2:09pm |
