![]() | Home > Technical > Terrafima steering drag link - Cross Rod Eye End wont screw |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2319 ![]() ![]() ![]() |
I've not experienced this issue personally but my solution would be to cut the first 10mm (or however much is required) off the ball joint thread to stop it bottoming out prematurely. Or cut half the required amount off both ball joints > 110 XS Double Cab
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3493 ![]() ![]() ![]() |
Fitted a heavy duty drag/track rods for a friend, but I do not know by which supplier. They fitted right away, did not need to chop anything.
I think it is normal to have a few threads exposed on the HD drag link as there will also be a locknut. That is different from the original LR drag link where it is slotted and clamped to fix in place (IIRC the original drag link has missing internal threads for the first 1/4” or so. The drop arm side, or cross eye as it is called has an extra length where there is no thread. That could be the part that is bottoming out? But do not know its purpose. Search for ANR2858 for some pictures. You should ask how much thread is exposed. Goal is to have the same overall length, otherwise you get more steer to one side than the other. The track bar should also be exact same overall length else you will get more toe in/out. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 ![]() ![]() ![]() |
I have the same drag link - went on no problem. Rgds.
Chris |
