Home > Technical > Transmission "clunk" - 2011 Defender 90 hardtop -
Page 2 of 2 <12
Dinnu
Can read here that it is very common failure:
https://www.defender2.net/forum/topic62521.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #920336 7th Sep 2021 10:31am
Ianh
To test your A frame ball joint I read this post on another forum.
“the way i check for play in the a-frame is with the vehicle on the ground get someone to rock the wheels at 3 and 9 o'clock as if you are checking wheel - bearing play, this will show play in the a-frame, also with the handbrake applied rock vehicle back and forth while laying under neath and you should see any movement present and this will also show play in the link arms too.”
In principle this seems a good way to visually check the movement of the ball joint and A frame bushes. Just make sure you are on a flat surface, the handbrake is working and is applied.
Do others test the A frame ball joint and bushes this way ? Has it been successful in showing / identifying A frame issues ?
Post #920351 7th Sep 2021 11:58am
Tractorman
Scotland 2011 Defender 90 Puma 2.4 HT Indus Silver
Darren - many thanks for your advice - much appreciated. Jim
Post #920668 9th Sep 2021 9:45am
Page 2 of 2 <12
