Home > In Car Electronics > Focal iBus 20 sub. Disappointing |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
It’s compromised by the size of it and will never be like your local spotty faced Fiesta boy’s ‘system’.
If you want your diaphragm rattled…. Fit a large separate amp, big sub box, big mid speakers, crossovers and focal tweeters facing you on the dash. All the standard Land Rover speakers then need the wires disconnected. |
6th Aug 2021 6:53pm |
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 176 |
A boy racer boom is not what I’m after. I’m after a full warm sound. What I have sounds weak and missing many frequencies.
I have read many reviews of the focal sub and all seem rather pleased with it. As I said, any “regular car” basic stereo would knock socks off my current setup. I can’t believe a dedicated sub, even a mere 8”, can’t deliver what a regular car sound system delivers. |
6th Aug 2021 8:26pm |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 605 |
If you haven’t done the other speakers yet I’d strongly suggest you do. The sub is the finishing touch but the focal woofers/tweeters are night and day from the original setup https://instagram.com/bentheoandrews
6th Aug 2021 8:38pm |
Really? I thought the original speakers were ok for the mid and treble. I mean they sound ok for the high stuff, just have no bass. Which was what I was hoping the sub would sort. You recon the focal components will be the solution to fill it out?
6th Aug 2021 9:47pm |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1431 |
Nope, all the standard fit 4" speakers are poor, including the "upgrade" ones fitted as part of the subwoofer option.
Just one pair of Focal PC130 in the rear makes a world of difference,. Agree Volvo systems are very good. |
6th Aug 2021 10:16pm |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 191 |
I’m at the same stage as you… yesterday fitted Ibus 2.1 to Mud Sub Locker. Couldn’t do the speakers as didn’t have the right spade connectors for the Focal ES100K speakers. I thought just having more bass would make it loads better - and it is better, but still plenty missing. Can’t wait to get the new speakers in. |
7th Aug 2021 6:47am |
I do take the point that the stock speakers are likely to be crap. Also that 4” lack size required for warm sound. Im just worried at present I’m going to spend rather a lot of money chasing something I’m not going to get.
When I do replace speakers I will certainly go PC130 in the rear. I’m also reading up on 130mm speakers in the front too. A bit of cutting and manipulation required but nothing too brutal. Seeing as the PC130s are much cheaper, I may do this first as an incremental upgrade and assess how this larger cone performs at filling out. I’m also aware of some making new enclosures for the rear speakers high up in the top corners. Also considering this as the plastic trim the speakers mount to is as flimsy and poorly fixed as can be. I suppose replacing the stock speakers is a must eventually. I also have a fall back of selling the iBus 20 and just buying an amp and sub to sit in the boot. Removable when needed. Nothing too big and boy racer like, but something with more than the focal offering. Was hoping to avoid as I do like the compact focal mounted to the rear of the cubby. |
7th Aug 2021 7:39am |
I’m very interested in how you think the esk100 perform in filling the sound out with the iBus sub. I’ve no doubt they’re top speakers, I’m not questioning that, I’m just wondering if they’re right for our defender beasts. Post back when you’ve installed. |
7th Aug 2021 7:43am |
I put the ES100k tweeter/woofer kit in. Pretty standard setup for a Defender audio upgrade.
https://www.mudstuff.co.uk/collections/aud...weeter-kit Not sure what Defender you have but although mine had the grilles up top for tweeters, there weren't any fitted. The ES100K kit gives you the woofers and tweeters with crossovers to separate the highs and mids then you've got the sub to fill in the low end. https://instagram.com/bentheoandrews |
7th Aug 2021 9:56am |
Got a 110. 2014 xs station wagon
How did you find the esk100? Mid and treble I already have with the stock, although probably pretty crap. I worry by spunking £250 on those great 4” speakers I’ll just have better mid and treble with the same hole in frequency and weird sounding music. The more I think about this, the more I realise there is an issue. What with, I don’t know. I listen to a range of music, from rap to rock. Any other speakers I listen to, whether in another car, a stereo at home, a rubbish Alexa, kitchen ceiling speakers, the songs sound similar. All have the frequency range and the song sounds as intended obviously with more or less bass depending on the product. The defender sounds wrong. Missing bits. Unbalanced. Tempted to drop by a car audio shop and let them have a quick look and advise. |
7th Aug 2021 10:09am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5739 |
I did all new speakers and sub at the same time, and must say was, and am very impressed with it. Get many positive comments on it too.
7th Aug 2021 9:35pm |
Was it the focal setup or something else?
7th Aug 2021 11:17pm |
Definitely get it checked out if you aren’t sure. Mine was a DIY job just from people advising on here. Changed the head unit, added a sub and switched out the speakers. Had to get a live put in from battery to sub and even the guys at the auto electrical centre said how sweet the sound was. I listen to mostly electronic music - classic house, drum and bass etc and as long as I don’t have loose change rattling in the cup holders it’s really good.
Disclaimer - I don’t actually have the focal sub but it is just a LR cubby mounted sub I got off eBay and I don’t think it’s supposed to be any better than the focal. https://instagram.com/bentheoandrews |
8th Aug 2021 6:04am |
Thanks for the input on your system. Going to consider replacing the speakers too once I get my head round any issue I have or don’t have.
8th Aug 2021 6:11am |
