Home > Maintenance & Modifications > Double spare wheel carrier
Log splitter
United Kingdom 2014 Defender 110 Puma 2.2 XS DCPU Corris Grey
I want it fit a Gobi x twin rear wheel carrier to my 2014 defender tdci double cab pick up. I understand it won’t fit because of the hinges on the tailgate. So if I change the tailgate to put side hinges on. Which I think is posssible. Can I then fit the new rear bumper with double spare wheel carrier. They bolt to existing holes in rear cross member. I know they fit to station wagons. So I suppose the question is. Are the rear cross member the same on double cabs and station wagons. If so then my thinking is that it would fit if I i side hinged the rear tailgate.
Post #914455 28th Jul 2021 3:14pm
Yes, the crossmember is the same across all of the (similarly aged) models. If you remove the tailgate hinges then you're left with a crossmember as if it was a van or station wagon. Darren
Post #914696 30th Jul 2021 6:53am
Log splitter
Thanks for that info. I can now go ahead with ordering side hinges and a wheel carrier.
Up to now I’ve relied on a second spare tyre slung on the roof rack. New bundutop tent takes up most of the roof rack so looking for alternatives. Changing tubeless tyres whilst out on travels is also not easy. Having a twin wheel carrier makes everything easier and the rear bumper gives the Landy more protection as have been rear ended before 😳
Can you suggest the side hinges I need and can I use the same catches to lock in place
Thanks
Post #914702 30th Jul 2021 8:10am
You can use all of the standard hardware from a regular rear door - hinges, lock, striker plate, etc. - or you could use any of a number of aftermarket hinges from the likes of Optimill.
You can even buy the whole lot as a kit, although it's Britpart so I can't vouch for the quality:
https://www.paddockspares.com/tailgate-rear-half-door-kit.html
I suspect that you could get better if you sourced all of the parts separately. Essentially though, you're replicating the regular rear door set up but without the top hinge, so will need all of the components that entails. Darren
Post #914709 30th Jul 2021 9:02am
Log splitter
Brilliant. Your a star 😀
Post #914713 30th Jul 2021 9:47am
Don't forget to share some pictures. We like pictures Smile Darren
Post #914717 30th Jul 2021 10:43am
Log splitter
Will share pictures shortly. Fitting ostrich wing awning this weekend and finish wiring for solar panels and bundutop tent.
Ordered hinges for tailgate for now. May convert to new half door conversion kit in future .
Post #914723 30th Jul 2021 11:10am
Log splitter
Notice damage on rear near side wing. Got rear ended in Windhoek Namibia last year. Hence why I want to fit a rear bumper with twin wheel carrier 👍. Not going to get it repaired any more than it is as I’ll probably inflict more cosmetic damage on it.
As long as mechanics are all sound, I’m ok with that
Post #914724 30th Jul 2021 11:13am
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Lovely looking 110, may I ask what the rear canopy is?
Best,
Alex 110 Tdci Double Cab
Post #914733 30th Jul 2021 11:43am
Log splitter
Bushtech canopy supplied by APB trading Its very robust.
Post #914745 30th Jul 2021 12:07pm
