Home > Td5 > TD5 welding work |
Yes, it should fire back up again. The only thing to watch for is whether your alarm system has a back up battery sounder (BBUS) as this needs to be disarmed before disconnecting the battery. The process for that is in the handbook. I can't remember when they were introduced though, so it may not be relevant for your '02 model. Darren
28th Jul 2021 2:11pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3425 |
Replaced a cross member and used a combination of stick (inverter at 72Volts) and mig welding. All I did was disconnect the battery. It started right away. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
28th Jul 2021 7:36pm |
