Home > In Car Electronics > New battery does not go into trickle mode with Ctek
kmac
Finally replaced my factory provided starter battery with a Yuasa YBX5019
When it arrived I set it to charge in the house with the Ctek MS 5.0
Left it for a week but it never went past stage 7, green battery to stage 8 - trickle charge
Anyone know why this is the case?
Post #913923 24th Jul 2021 10:24pm
kmac
Internet reading suggests it may need up to 10 days on stage 7 before going to stage 8
Post #913940 25th Jul 2021 6:51am
Doesn't sound like a problem - Stage 7 is "Fully Charged".
Stage 8 is just gives a pulse when necessary to keep the battery fully charged - it may well be doing it and then dropping back to Stage 7 whilst you are not watching.
Post #913952 25th Jul 2021 8:27am
kmac
Thanks Supacat Thumbs Up
Post #914034 25th Jul 2021 9:23pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Oddly I find that my Yuasa batteries often seem to be 'stuck' on Stage 4 while they are in the vehicle. I wondered if it was the slight current drain (25ma) from the Lodar remote receiver, clock etc, that just keeps the voltage slightly down and fools the charger. When you check it with a meter the battery sits at 14.8V on the charger. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #914220 27th Jul 2021 9:09am
kmac
Don't measure the battery voltage with the charger on - it is bound to be high.
Disconnect charger and wait a little while then check voltage at battery. Should be about 12.7V or little more. Mine was 12.9V fully charged.
Post #914525 28th Jul 2021 8:48pm
mikeh501
Mos 5 is only just man enough for that battery too. I’ve got a mxs10 for 110ah
Post #914574 29th Jul 2021 8:30am
BogMonster
Yes I know that, what I meant was that the slight drain from the 'sleeping' demand might fool the charger by not quite allowing either the voltage to get up to expected level, or the current input to drop to a low enough level for it to deem the battery to be full. Mine all sit at 12.8-12.9 if full and in good condition. ---
Post #916010 8th Aug 2021 10:04am
kmac
Thumbs Up
Post #916336 10th Aug 2021 12:40pm
