Home > Technical > Bulkhead Strip down & Removal
JG007
New Zealand
Good morning all!
Can anyone direct me to a thread showing the steps to strip and remove a 300Tdi bulkhead and windscreen, including dashboard removal? I assume this has been covered but having trouble finding the right thread.
If there is also a thread showing how to refit bulkhead and windscreen and reassemble that will no doubt be very useful!
Thanks in advance.
Post #913514 22nd Jul 2021 3:10am
Co1
Ignore this post. Just told you how to remove the dash on a puma, which was pretty pointless!
Post #913518 22nd Jul 2021 5:03am
excossack
Here is a link to what my td5 110 looked like.
https://www.defender2.net/forum/topic49854...t=bulkhead
Might give you a few ideas 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #913529 22nd Jul 2021 7:20am
donmacn
To be honest, though the job's been done a lot, it's really very 'bitty' - by which I mean lots of little fixings and components, though none of it is very technical.
What I'd suggest is to take lots of pictures as you go, so you have references for the rebuild, and can hopefully avoid the hassle of fitting something before realising you should have fitted something else first. For example,don't fit the dash backing panel before fitting the windscreen wiper tubes (not a great example, but hopefully you'll get what I mean).
Also, have a bunch of egg boxes and plastic bags and labels to hand to make sure that you can keep things organised.
This is the place to ask specific questions though. I've had my dash out a couple of times, bulkhead once,but I've done two other bulkheads too. Not as especially technical job, but a bit involved. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #913629 22nd Jul 2021 6:53pm
Dinnu
I have placed some pictures in my restoration thread, pg12, however not an account how to strip or assemble.
https://www.defender2.net/forum/topic72365-165.html
But I try to give a short account to remove the dash here (hopefully without too many mistakes):
1. First to remove is the binnacle, and the heater controls
2. Remove passenger side grab handle and wiper motor cover
3. Remove top dash. There are screws on the underside too.
4. Remove plastic rivets and Gently pull out the grey plastic trim. Very fiddly. Mine is pre 2002 design. You have to press it almost to the point of breaking it. Just cross your finger that it does not.
5. Remove the windscreen demister and the metal panel that was behind the greyish plastic trim.
6. Remove the lower dash. There are 2 M5 screws at the top side, one would be behind the harness. There are of course the self tapping screws around the bottom edge.
To install is the reverse procedure. Putting the greyish plastic trim back in was very difficult. I spent the best of 2hrs trying to get it in as delicately as possible, as I was working with 33 year old plastic. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #913631 22nd Jul 2021 7:19pm
excossack
On the link I posted is a list of bits I ordered for when mine was done. Some I knew would need replacing, others were just in case. 1999 Defender TD5 110
Regards
John M0VAZ
Post #913632 22nd Jul 2021 7:19pm
