Home > Puma (Tdci) > Leaking transfer case
Ijk10
Wales 2007 Defender 110 Puma 2.4 CSW Keswick Green
Hi all
Had a new clutch and output shaft fitted last month. There was a leak on the transfer box that I asked to be fixed at the same time. A week later it's leaking again and the Garage are saying it's a different leak and a new transfer box is required. At a cost of £800 plus VAT. Surely an oil leak shouldn't cost this much to fix?
Post #912240 13th Jul 2021 6:46pm
Pacha
Where is the new leak coming from? Rgds.
Chris
Post #912241 13th Jul 2021 6:48pm
Ijk10
The garage have said it's at the top end of the rear...
Post #912243 13th Jul 2021 6:51pm
hank
Hi. I see you’re in Newport. Which garage did you use? > 110 XS Double Cab
Post #912273 13th Jul 2021 9:29pm
Probably time to change garage!
The only cause of a leak which might justify the "replacement transfer box required" comment would be if the leak is due to the enlargement of the holes in the casing which support the second motion (aka idler gear) shaft. There are ways to repair this.
Such a leak wouldn't be coming from the "top end of the rear", however.
Post #912278 13th Jul 2021 9:44pm
Ijk10
Sent you a dm buddy...
Post #912279 13th Jul 2021 9:44pm
