![]() | Home > Maintenance & Modifications > Wiring in DRL so they come on with ignition?? |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 169 ![]() ![]() ![]() |
Plenty of magic boxe s about.
Powerfuluk do one that links to the side lights as well. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4776 ![]() ![]() |
I have DRL'S on a 2.4 Puma. They come on when the ignition is on. As I have a connection to the side light they go off when the lights come on. As they do not dip they would blind on coming traffic at night. If you want them on all of the time don't connect them to the side light. Mine are Ring Aurora. 1982 88" 2.25 diesel
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
If you fancy wiring them up yourself, here is the relay wiring.
![]() Click image to enlarge ignition only= drl on ignition+ side light = drl off |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2320 ![]() ![]() ![]() |
And use a normally closed relay 😉
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3532 ![]() ![]() ![]() |
87a is the normally closed side of the relay contacts.
87 is the normally open side of the relay contacts. You may find relays that only have 87a or only 87.. in that case make sure it has the 87a. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
