Home > Technical > Indicator relay stays solid randomly
Matt110
Hi all,
Could you help me work out if this is normal and whether its an earthing issue or a failed relay?
Issue is hazards/indicators, part way through most journeys, the relay stops flashing and just goes to solid on when you either turn on the hazards or the indicators. They function normally apart from not flashing.
Feels like a relay problem to me - if it were earthing they would either not function, or turn the wipers on whenever you indicated right!! (joke i promise). Rolling with laughter
After keying off for about 20 minutes, the relay "resets" and returns to normal functionality. But keying off and waiting only 10 seconds doesn't reset it.
Is this common?
Post #909051 23rd Jun 2021 8:22am
Martin
Site Admin
Standard indicators and factory flasher unit or LEDs and/or aftermarket flasher?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #909054 23rd Jun 2021 8:51am
Matt110
All standard Smile
Post #909055 23rd Jun 2021 8:53am
Martin
Site Admin
Both sides a problem?
If so I would swap out the flasher relay with another as a first step.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #909056 23rd Jun 2021 9:10am
Matt110
Yep, both sides exactly the same. It's like it's lost its capability of flashing but "indicates" left, and right, and hazards, all correctly and with lamps lit, but not flashing.
Will swap it out and see what happens. Cheers Martin. Thumbs Up
Post #909058 23rd Jun 2021 9:11am
