![]() | Home > Technical > Wheel stud survey - ideal length for HD rims? |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 632 ![]() |
After some advice from another forum, I think I've managed to find a solution to this myself with a cheap off the shelf stud if anyone is interested:
This is what I think to be correct: Virtually all Defender wheel studs are 39mm long (end to end) - which are the ones that end a couple of mm short when fitting Wolf wheels. The 56mm studs solve the steel wheel issue but are very long - too long to go back to alloy wheels due to the different wheelnut design. But there is a 45mm stud, which should be perfect - allowing Wolf wheels to fit with a flush nut/stud and still being short enough to allow me to revert back to alloys if the mood strikes. The part number is FRC6137 - watch this as some people have reported receiving them at 39mm and 45mm - think it depends on the manufacturer. I've just ordered a set of genuine studs and I called and had the distributor measure them at 45mm. I haven't yet measured those on my 2010 90, but I'm assuming that they are 39mm (I'll have egg on my face if they're already 45mm) Fingers crossed this works when they're fitted! Here's some photos, the lengths on the ruler aren't massively clear due to the angle but had these lengths verified by the parts suppliers. Both the 45mm and 39mm have the same number of threads, but the distance from the inside of the flange to the start of the first thread seems to be a good 3-4mm longer on FRC6137 (marked the gap on a piece of paper and compared it with the scale on the rule) FRC6137 45mm studs: https://www.brit-car.co.uk/shopimages/prod...RC6137.jpg Standard defender 39mm studs: https://www.brit-car.co.uk/shopimages/prod...00010.jpeg Extra long 56mm studs https://www.brit-car.co.uk/shopimages/prod...RC7577.jpg |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
Picture links don't work
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3644 ![]() ![]() ![]() |
The length of FRC6137 really is a mystery.
Seen places advertised at 45mm and others at 39/40mm. I test fitted my wolf style rims on my rear axle (drum brakes) and counted 7 turns until the nut gets tight. That means I have about 10.5mm of nut connection. which is a bit too little for my comfort. My studs are 39mm. Thoughts of what I could do? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
