Home > Puma (Tdci) > Nanocom Typical Readings
Moffett
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Does anyone have a list of typical readings for a 2.4? I have an issue with black smoke under load. I have noticed that it happens when the EGR measures above about 30% when driving in 6th. EGR goes to 100% at idle and drops to 0% under acceleration in the lower gears, but has a tendency to open partially in 6th gear no matter what. It logged faults for turbo under boost, mass or volume air flow and egr mechanical failure the other day and gave the engine light. The fact that the EGR is so active would indicate that it is opening and closing, but what would cause it to open excessively? Any comments you might have would be greatly appreciated. The truck is running well in all other gears apart from 6th at the moment.
Post #907843 14th Jun 2021 8:29pm
Moffett
Anyone with a 2.4 and a Nanocom willing to do a quick run and get some baseline figures? Such as at idle, stationary at 3k rpm. Circa 3k in fith and 6th. Would certainly help me decipher what I am seeing! Thanks, Dave.
Post #907947 15th Jun 2021 2:45pm
Minch90
Could do this with my UltraGauge if that works? 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #908035 15th Jun 2021 8:51pm
Moffett
A kind offer, I am unsure if the readings are the same, ie. Voltage, % etc. But they should be similar? I will ask on the Nanocom site also.
Post #908072 16th Jun 2021 6:25am
Minch90
At 3000rpm in all gears and when static was 0%. Load was positive at each step. When lifting off EGR opened at about 2500rpm when load was down to 0%. Daisy loved 3000rpm in 6th, speedy ๐Ÿ‘ 2.4TDCI 90 - everyday brilliance
Post #908203 16th Jun 2021 6:43pm
Moffett
Mine appears to be working differently to yours?! Egr is 100% at idle/no load and at 0 under acceleration! I wonder if it's just a difference in the Nanocom and Ultragauge. Did you get any reading between 20 and 50%?I have a feeling my egr is just fine. I have too much fuel at times for some reason.
Post #908207 16th Jun 2021 6:57pm
Moffett
And what speed did you reach at 3000rpm in 6th? I hope I hadn't you too far over the limit!!
Post #908208 16th Jun 2021 7:00pm
Minch90
EGR will bumble around 20-40% when under low load such as 40 in 5th on flat, opens more when load drops.
3000 in 6th was beyond where the limiter was ๐Ÿ‘ we were both smiling 2.4TDCI 90 - everyday brilliance
Post #908209 16th Jun 2021 7:04pm
Moffett
Thanks for your help with this. I appreciate you taking the time.
Post #908265 17th Jun 2021 6:39am
MK
Hi guys
I tried to ask BBS about the meaning of "compression balance "ON" but they said, no idea Shocked
Any ideas? should be on or off Rolling Eyes
 Puma 110" SW
Post #1037878 19th Jun 2024 2:23pm
MK
really no one? Puma 110" SW
Post #1037946 20th Jun 2024 12:01pm
Suspect VCV, which wonโ€™t log any DTCโ€™s but might well be throwing other things out.
Also lube the Turbo actuator pivots with 3in1 light oil.
See how that goes, just some ideas.
6th gear is where VCV failure is noticeable when power is down in the upper most gears. TheThunder Rolls๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿ‡บ๐Ÿ‡ธ
โ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1037959 20th Jun 2024 4:22pm
MK
Thx. So I assume that reading should be off then. Puma 110" SW
Post #1037960 20th Jun 2024 4:27pm
