Home > Maintenance & Modifications > Deoxidizing aluminium parts
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Hi guys, doesn't anyone have a "trick" or used a commercial product to refresh the appearance of Aluminium engine parts? I'm rebuilding a 300tdi and want to make it look a bit better than it does before it's fitted to the new chassis. Some parts I'll have aqua blasted but don't want to remove the cylinder head or timing case if I can avoid it as the engine was fully rebuilt about 4yr ago and runs perfectly. Cheers Craig
Post #907668 13th Jun 2021 5:15pm
G4V JW
I’ve used this on a lot of Ali parts, great for removing the marks around rivets and anywhere else that two different metals join
http://www.raceglaze.co.uk/car-care-exteri...e-cleaner/
It’s the protecting it after that counts though so it doesn’t oxidise so quick again Instagram; @gavin_walding
Post #907676 13th Jun 2021 6:25pm
Pacha
Used the same to good effect.
As said, needs protecting after treatment. Rgds.
Chris
Post #907677 13th Jun 2021 6:42pm
northernerindevon
United Kingdom 1986 Defender 90 300 Tdi HT Nato Green
I've had reasonable success with Raceglaze - used on an Allisport header tank.
What I'd like to do is polish it to a bright as new finish (yes, yes, a bit tarty but why not!); what would be the best way to go about this? Some sort of metal polish? Brasso?
Cheers, Paul
Post #907720 14th Jun 2021 4:20am
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
This stuff works well on aluminium alloys for a bright polished finish. Use an old toothbrush for intricate areas. Buff with a clean soft cloth.
https://www.halfords.com/motoring/car-clea...36217.html
Post #907726 14th Jun 2021 7:03am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
You need some of this, marine grade metal polish and fantastic……
 Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #907755 14th Jun 2021 10:45am
Moneypit
Thanks for all your suggestions, I've ordered some Raceglaze and will try to track down some Dri Wash polish, none available on Amazon. Craig
Post #907793 14th Jun 2021 4:24pm
