Home > Technical > Gear Knob/Shifter weight R380
G_unit
Hi all,
I have a gear knob machined out of solid brass, more or less exactly the same size as the standard r380 knob but a good deal heavier. Will the weight be an issue on the gears? I don’t want to wear the gears and i know some say this and that about resting your hand on it when in gear
Post #907409 11th Jun 2021 1:01pm
gilarion
The simple answer is it will not wear out your gears. Many aftermarket gear knobs made out of either alloy or steel are a lot heavier than the original plastic and these metal gear knobs have been available for a long time without any issues. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #907420 11th Jun 2021 2:44pm
G_unit
That’s reassuring to hear. Thanks for reply. Now to dig out 1/2 inch taps and get it fitted.
Post #907425 11th Jun 2021 3:14pm
The Disco2 knob is lead-loaded and weighs more than a solid brass knob would, as a part of the Disco2's sound-deadening, anti-vibe strategy.
Post #907443 11th Jun 2021 5:11pm
