Home > Maintenance & Modifications > Fitting Safari Equip Tree Slders to a 110. |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 |
I definitely didn't have to do that much when i fitted ours.
That's surely worthwhile feeding back to equip or at least pointing them to this thread so they can read just how much we're all struggling to fit their products. Would be good for them to see so they can adjust. They make some lovely kit but that's all kind of pointless if you need an angle grinder to adjust it before you can fit it!! |
16th Jun 2021 9:09pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17526 |
As far as I remember I just drilled a couple of holes and bolted them on when I fitted mine, I don't even remember using any shims or spacers. I'm amazed that you had so much trouble! What does that say about LR build tolerances?
16th Jun 2021 9:35pm |
Struggling with it being the defenders fault entirely... If it were that bad the (comparably accurate) overall length of the doors would mean the doors wouldn't fit on half of them surely?
.....edit. Though admittedly it should be easier to order a length of oblong bar, bend some tube and weld it on and pop some brackets on it in terms of repeatability of manufacturing and tolerance controll than an ally body on a steel frame... Put together with rivets. |
16th Jun 2021 9:39pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4226 |
It probably would have been possible just to do that, but then I’d have had to trim the front arch and had a gap to to rear one which would have irritated the hell out of me. I don’t think the cutting that bracket has actually compromised the strength of the slider that much. The things are well overbuilt.
I’ll put some better pics up when I next get chance to work on the 2nd slider. 2007 110 TDCi Station Wagon XS |
16th Jun 2021 9:41pm |
Quick pic of the side I’ve done
Click image to enlarge I think it looks rather smart, it was worth the stress to avoid cutting the arches and have it sit in nice and tight to the body. The other side is proving much less hassle for some reason, so should be all done tomorrow 2007 110 TDCi Station Wagon XS |
18th Jun 2021 5:40pm |
