Home > For Sale & Wanted > [For Sale] 300tdi engine
lb73
Wales
No longer needed thanks to an M57 conversion, I was planning on keeping this however I just haven’t got the room. Out of my T reg 110, however I believe it’s not the original engine as it has RC (presumably reconditioned) stamped on the block. Plus looking back on the online MOT checker prior to me buying it, it makes reference to the clocks being changed to tally with the engine change, current mileage is 118k however I can’t verify that.
History wise I had very little with the vehicle when I bought it (at 106k in 2016), however since in my ownership I’ve serviced it every 5k, treated it to a engine cover , changed the clutch 9k ago,recond the alternator and changed the mechanical fuel pump. It always ran/ started well , never used any oil however did become smoky on cold starts, clearing when warmed up. Its has had the egr delete done prior to me owning it.
I’m not expert on theses but inspecting it after the removal the turbo may need work, however it still started, ran and stopped ok. Just note on the photos it shows the gearbox bell housing which will not be included.
Obviously buyer would need to collect (from LL13) however I can help with loading (engine crane)
£400 Ono
 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2002 Dax Rush 3.9 V8
2012 Audi A3 tdi
2020 Renault Kangoo electric
Post #906882 8th Jun 2021 6:50am
lb73
Wales
Sold! 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #906986 8th Jun 2021 11:50pm
LR90XS2011
what can you tell us about the M57 DEFENDER 90 TDCI XS,
Post #906990 9th Jun 2021 5:34am
lb73
Wales
So far it’s been straightforward enough, just in the process of the wiring which uses a modified harness from Wiseman engineering, along with a spacer plate and P38 bell housing for the r380. Physical size it’s seems to be slightly smaller than the 300tdi and I’ve had to use a td5 rad and intercooler and a modified down pipe.
I have got a build thread running which I need to update, but hopefully fire up will be in the next couple of weeks!
https://www.defender2.net/forum/topic50187.html. Any questions - ask and i’ll try and answer them. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #907000 9th Jun 2021 7:06am
excossack
The link above did not work as there is a . at the end
ta 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #907012 9th Jun 2021 8:24am
