Home > Technical > LT230 filler plug |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 798 |
Found the answer, there is a small allen headed bolt in the centre you remove to check the level. It comes with the Roamerdrive kit when you have one fitted. BORG - Bucks & Oxon 4x4 Response Group
18th May 2021 8:21pm |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 259 |
Hi,
Should be a Torx 55 Dave Dave |
18th May 2021 8:58pm |
Sorry, I misread that, the T55 is the R380 Dave
18th May 2021 9:01pm |
At some point your transfer box has had a Roamerdrive overdrive fitted. These brass plugs with the small Allen key screw in the middle come with the kit. The idea is that by fitting this plug and checking the oil level at the Allen screw level your box will have about 1/2-1L of oil in addition to the usual box volume. This is so the overdrive has enough lubrication. You can take the brass plug out and replace it with a standard one if you want. Point 8 in the instructions http://roamerdrive.com/pdfs/dsinstall_all_Nov2016.pdf shows the plug. Great but if kit by the way, love my roamerdrive |
19th May 2021 8:06am |
It still has the Roamerdrive fitted.
Do I drain both transfer box and overdrive then fill each separately or just refill through the overdrive until it comes out of the level plug in the transfer box? BORG - Bucks & Oxon 4x4 Response Group |
19th May 2021 6:44pm |
So section 8 last sentence says drain both transfer and OD then refill as stated.
19th May 2021 7:01pm |
