Home > For Sale & Wanted > [Wanted] 90 Tdci rear diff
Likeomg
Any condition,
thanks, Liam
Post #901885 7th May 2021 10:49am
nicholas2012
Scotland 2010 Defender 90 Puma 2.4 HT Tamar Blue
Ashcrofts are a good company to deal with I bought one of their ATB diffs a few years ago
Post #901895 7th May 2021 12:43pm
You might want to bear in mind that the Tdci 90 front and rear diffs and the TD5 90 front and rear diffs are all the same, and are the same as almost all Tdci and TD5 110 and 130 front diffs (unless these have actually been fitted with the elusive four-gear diffs).
Most earlier 90 and 110 diffs (but not the Salisbury type), and most Disco1 and 2 diffs will also fit, although a Disco 2 rear needs the flange changed.
Bottom line, there are many, many sources of rear diffs for a 90.
Post #901909 7th May 2021 3:25pm
LR90XS2011
loads of disco diffs also fit
sorry repeated what Blackwolf said!! DEFENDER 90 TDCI XS,
Post #901912 7th May 2021 4:28pm
Likeomg
Thanks, wasn't 100% sure,
Post #901980 8th May 2021 9:56am
Piggy501
Scotland 1996 Defender 90 300 Tdi PU Arrow Red
Correct me if I'm wrong, but only 300TDi onwards are 24 spline diffs. 200TDi and earlier are 10 spline, so won't be compatible with shafts from a TDCi.
Post #901985 8th May 2021 10:28am
Indeed, hence my qualification "most" rather than "all".
Any from about 1994 should fit.
Post #902056 8th May 2021 6:08pm
