Home > Technical > 24 spline diff center in a 10 spline housing
Dinnu
Sorry could not find a firm answer to my question:
Can a 24 spline diff center be fitted in a 10 spline housing using the 10 spline ring and pinion?
At what point were the splines on the pinion changed from the large 4 splines to the finer splines?
Thanks. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #901833 7th May 2021 6:23am
ashtrans
Site Sponsor
yes, if the 10 spline housing is metric, to check this, look at one of the ends of the journal end cap bolts, if it has '8.8' on it, its metric,
yes you can use the 10 sp R & P
4 -24 spline approx 1993 Dave
Post #901867 7th May 2021 9:30am
Dinnu
Thank you Dave. That is clear.
Plan is to try to build a spare unit from a spare center after upgrading to your locker Thumbs Up
I can possibly get a broken 10 spline unit for practically nothing (hopefully the R&P are still serviceable) Wink 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #901881 7th May 2021 10:38am
