Home > Puma (Tdci) > Injector seals
Simon1979
Wales 2006 Defender 110 Td5 Silver LE Zambezi Silver
Injector seals
So this afternoon we've done my injector seals. All went well apart from refitting new rubber seals in to the rocker cover. Managed to get them in in the end. Very tight. Started the engine all fine running spot on. Took it for a good run for 20 mins or so. Get home to check for leaks. There's still a leak on number 3 coming thru the rocker cover seal. So my question is this common? What do I need to do to stop it?
Thank you.
Post #900961 1st May 2021 10:31pm
