Home > Puma (Tdci) > Engine cover question |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17443 |
It's a sort of rubber wedge-shaped prong thing that fits at the back of the cover and engages in a slot in the back of the cam carrier, as I recall. Also as I recall it is only available as part of the cover LBH500370 and not on its own, which is particularly unhelpful since the cover is around £50. It makes for a very expensive rubber prong.
I don't know if there is a Ford part number for the prong. You can see the offending item in the photo below, at the bottom right. Click image to enlarge |
1st May 2021 3:58pm |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 |
Thank you, that’s it.
I will make one from something. |
1st May 2021 4:59pm |
Just remembered, I’ve got some sugru, I’ll try that.
1st May 2021 5:47pm |
