Home > Technical > Part indentification
landiedave
United Kingdom 2006 Defender 90 Td5 XS CSW Tonga Green
Hi
Could someone advise me what this piece of trim is known as so that I can find one online to purchase. Passenger side missing. Apologies for the poor photo. It's a small plastic cover that goes over the bolts hold the metal retaining strap/guide to the front door.
Many thanks
Post #899993 25th Apr 2021 9:40pm
donmacn
Best advice I can give is to make 'new lr cat' a favourite google search.
If you go here you'll get a part number which you can plug into your preferred supplier.
I'm currently helping a mate do a bulkhead swap, so I think he needs at least one of these. When I did my bulkhead I neded both. Fairly readily-available once you have the part no.
Go to new lr cat; choose your vehicle; drill down to the right section; find your part number. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #899995 25th Apr 2021 9:50pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Here you go - Check strap trim MUC3036
Post #900012 26th Apr 2021 6:51am
landiedave
Brilliant, thanks Guys.
Post #900052 26th Apr 2021 10:26am
