![]() | Home > General & Technical (L663) > Webasto heater issue |
TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 197 ![]() ![]() ![]() |
Terve risulasi,
google the webasto telestart t91 operation manual there is explained how to switch modes summer/winter, program run times etc 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
risulasi Member Since: 22 Apr 2021 Location: Turku Posts: 7 ![]() ![]() |
Weather is getting cooler and heater will be needed soon, but I still have´t fully figured out Webasto heater function. I discovered lately that I can start the heater with remote knob only ONE time after turning engine off. If I turn heater on and off from knob, but don´t start engine after that, the heater wont start. Has anyone noticed same?
MikkoM Member Since: 07 Jun 2021 Location: Uusimaa Posts: 9 ![]() ![]() |
Did you change the Precondition setting to happen with fuel operated heater? If not, it does not heat it with it, uses electric if you have P400e Defender, it could similarly function with other models too. MY22 Defender 110 P400e S
redhowe Member Since: 14 Sep 2022 Location: Barcelona Posts: 3 ![]() ![]() |
Hi to the Finnish members on this thread. Could you help me out please.
I have a P400e (PHEV) which is great in Barcelona (runs on electric for the school runs) and, as we have a cottage in Lapland, I appreciate being able to quickly fuel up with petrol on long drives. One thing though - my family enjoy around 5 weeks in Lapland each winter and I really want to fit a Webasto as often the older family members don't want to leave the comfort of the Defender to brave -20 to -30C temperatures. For this reason I'd really like to have the Webasto fitted (petrol version). Do any of you have this fitted, and if so, where is it mounted? Both the internal controls and the heater (presumably in the engine space). I'd really appreciate photos as then my Spanish Defender can at least be spec'd as per the Finnish ones. Many thanks! Kiitos, Rob |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
All lovely problems to have… I just eat readybreak before I get in my old model defender in the winter
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
All P400e's already should have ThermoTop EVO Petrol version fitted from the factory (at least all Nordic ones do), please check from the menus as there is the selection for "Precondition with Fuel Operated Heater" selection, then it uses the Webasto for preheat the car and do you have the separate keyfob included with the normal car key? MY22 Defender 110 P400e S |
My Defender was bought in Spain so o need to have the Webasto fitted. A photo of the installed location would be ideal. Thanks in advance, Robert
hezor Member Since: 01 Feb 2021 Location: Nurmijärvi Posts: 53 ![]() ![]() |
Attached a photo of my Finnish-spec P400e that has a standard fuel-burner Webasto, and it is circled in red. The blue circle is the Webasto high-voltage electric heater that should be included in every P400e regardless of the market.
![]() Click image to enlarge 22MY Defender 110 P400e SE w/ Off-Road Pack, Driver Assist Pack, Cold Climate Pack, Comfort & Convenience Pack + ClearSight Rear-View Mirror & 11.4" Infotainment Screen |
Hezor, thanks so much for this which is incredibly helpful. I can now, hopefully, proceed to get the fuel heater installed here in Spain before we come to Finland in December.
Many thanks! Rob |
