Home > Wheels & Tyres > Offset
kipperthedog
Offset
This maybe a daft question, and I hope it makes sense....
Would I be right in assuming that if the outer edge of a rim is 33mm further from the vertical face of the wheel (where the wheel nuts are) compared to a standard defender white steel rim, it is an et0 offset?
Post #898683 16th Apr 2021 8:04pm
Dinnu
If the rim widths (the J number) that you are comparing is the same, then yes.
Edit.. somehow I was thinking about alloys.. but I see that you refer to 'standard steel'. I believe the offset for those is less than 33mm. So the answer might be No. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #898688 16th Apr 2021 8:14pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
This explains it better than words....
It is stand alone, not compared to any other wheels.
Post #898693 16th Apr 2021 8:35pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
That is a great visual explanation, one to keep and share in the future Thumbs Up Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #898701 16th Apr 2021 9:13pm
Dixy
United Kingdom 2007 Defender 90 2.5 TD CSW Cairns Blue
Is the offset and stud position the same as 405 Range Rover.
Post #898740 17th Apr 2021 10:32am
The offset is a feature of the wheel rather than the vehicle.
The stud position (pitch circle diameter or PCD) on a Defender is not the same as an L405 Range Rover so wheels are not interchangeable. It might be the same as the new Defender though, if that's what you mean? Darren
Post #898827 18th Apr 2021 7:37am
