Home > Maintenance & Modifications > Learning basic maintenance skills |
Smyles_ Member Since: 25 Aug 2018 Location: Copenhagen Posts: 518 |
For me, whilst a student, I had no choice but to learn. No better motivation than money... or lack of. I priced everything relative to pints! Stuart Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
8th Apr 2021 4:39pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2097 |
Some more advice. Avoid Hammerite. Lots better out there. Search on here for painting crossmember you will see solutions from buzzweld and arc-rite . Ie corroless paint system. Plus frosts. Oh and be careful using a wire brush or wire wool on aluminium. Ie chequer plate. Ferrous metal residue on aluminium can cause issues when painting. First thing to do is clean out all the nooks and crannies in the wheel arches, chassis and crossmember etc on a regular basis. Often this is neglected and you will find they are caked in mud that stays damp and causes corrosion. |
8th Apr 2021 5:53pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
I never understood the use of breaker bars for removing wheel nuts.....Unless your driving a wagon all you need is a decent socket and one of these: Click image to enlarge and one of these: Take the strain from nut removal. Hit the slider bar with a socket attached with a hammer and all will loosen! Last edited by nitram17 on 11th May 2021 8:55pm. Edited 1 time in total |
11th May 2021 1:58am |
It wasn't for the wheel nuts. My first requirement and discovery of their purpose was for removing the old bolts holding the tow ball to the drop plate. First bolt came off with hammering, the second had other ideas. Stuart
11th May 2021 10:33am |
87110 Member Since: 14 Nov 2020 Location: Athens Posts: 13 |
Interior, exhaust, general servicing and smaller parts
Stripping the interior to a certain degree (removing seats, shifter boot, headliner) is quite easy and will require you getting under the car, which is the proper way to understand what trans fluid tastes like. Same goes for the exhaust (from the catalytic converter back) and its damned rusty bolts. Knowing how to remove all kinds of rusty bolts is a must for a defender owner. If you want to do some rust removal or painting its better to start with smaller, non-visible parts like the battery mounts. Changing fluids, batteries, tires and light bulbs is easy and very helpful and will teach you much about using tools. I wouldn't do bodywork, since that requires some experience, but removing the bumper and hammering out any dents is fun. One spanner of each size, from 4-26mm is good to have and having doubles of some sizes (10, 12, 13, 14, 15, 17, 19, 21) are necessary. Several screw drivers, a few allen keys, a hammer, a mallet, different kinds of pliers and lots of WD-40 are also good to have. Clamps are extremely versatile and highly recommended but not necessary. You might be able to get under the car as is but if you lift it to do anything more than a wheel change jackstands are absolutely necessary. the factory jack will do just fine. And of course don't forget safety glasses and a respirator, which is better to have and not need than to need and not have. Good luck! |
20th May 2021 4:48pm |
Magoyo Member Since: 04 Feb 2022 Location: Buenos Aires Posts: 47 |
i want one ¡¡ |
20th Feb 2022 12:26am |
and a good pair of ramps make it much easier to work under the truck and wash the chassis
20th Feb 2022 12:35am |
