Home > Technical > Hazards flashing after brake input? How?
jst
2010MY 130 2.4
i was adjusting the piston length on the 130 over the weekend to take out some of the slack in the pedal.
On assembly i slightly misaligned the piston into the master cylinder.
on pressing the pedal, which was rock solid as expected, that was until the piston slipped across into the recess in the MC.
At that point, there was a jump in the vehicle as the brake system was shocked and the hazards came on.
Not come across this feature on the Puma before.
they go off with an ignition cycle. (engine was running at time). turning hazards button on/off or indicators didnt turn it off, so a separate feed to the hazard module had been actuated.
i am presuming the sudden change in brake pressure initiated it? but how? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #896326 6th Apr 2021 8:39pm
Co1
It is pretty common in “modern” cars to flash the hazards automatically under heavy breaking. Wasn’t aware if it in a defender thigh but it might be the case that there is a pressure switch being triggered somewhere.
Post #896351 7th Apr 2021 5:05am
Dinnu
Never seen any pressure switch on the brake lines. Defenders are still old design. The brake light switch is under the dash, there is a plastic cover protruding where the fuse box / obd port is located.
Unsure if the ones with ABS have anything though.
Does the hazard or the indicators trigger anything else? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #896353 7th Apr 2021 5:21am
There is no evidence on anything like this on any of the electrical diagrams for the vehicle, and the only thing I can think of is that it is a feature (probably unintentional) of the alarm system. There is no way that anything connected with the brakes could activate the normal hazard flasher circuitry, but a sudden shock could activate the alarm. However the alarm should not have been activatable (if such a word exists) with the engine running, so something unexpected has happened. Very bizarre, and probably unplanned.
Post #896395 7th Apr 2021 8:30am
dorsetsmith
Post #896438 7th Apr 2021 11:13am
Ianh
That’s a very informative link DorsetSmith. I never knew their was an inertia switch on the 10AS alarm module for vehicles with central locking.
Post #896442 7th Apr 2021 11:29am
jst
Ok, well symptons suggest its part of the alarm then ready attached link. Guess it picked up a large inertia shock..
Doors wouldn't lock on fob at that point either. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #896443 7th Apr 2021 11:39am
