Home > 130 > Chassis bracket measurements request |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
I'm looking for the dimensions of the brackets shown in these photos of AndrewS's longshanks build if anyone has a rule and a spare five minutes please?
Click image to enlarge Click image to enlarge My chassis was supplied with the wrong brackets, the supplier has kindly offered to make some new ones but they need dimensions to work from. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
28th Mar 2021 9:56am |
Oldrover24 Member Since: 25 Nov 2019 Location: Manchester Posts: 10 |
The drawing is one that sits on the body cross member, small gusset piece not shown but easy to guess the size. for the rear mounting rail I used a piece of 40mm box section and added mounts at the ends so I now have tie downs in the tub. Think I have a sketch for the centre bracket somewhere, same as ones across the rear.
5th Apr 2021 10:48pm |
Click image to enlarge Click image to enlarge |
5th Apr 2021 10:51pm |
Oldrover, that is immensely helpful thank you! I like your solution for the rear mountings too. If you do have a sketch for the middle bracket it would be very much appreciated. 1985 127 V8 Build Thread
6th Apr 2021 10:49am |
Hi Shroppy, this is a rough sketch for the other style bracket, hope it helps, side flanges not on drawing but again easy to work out.
7th Apr 2021 8:36am |
Superb! Many thanks. 1985 127 V8 Build Thread
7th Apr 2021 8:42am |
