Home > Maintenance & Modifications > Puma 90 Rear Pad Replacement
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Puma 90 Defender
2.4 2010
Ordered new rear pads.... Ordered fitting kit...
Gonna buy the Tool to retract pistons. Do I need...
1. A Caliper Rewind Tool? Rotates the pistons back in
2. A Caliper Spreading Tool? Pushes the pistons back in
Finally is it the same Tool for the front?
Cheers in advance
Clemmo Thumbs Up Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #894315 27th Mar 2021 4:19pm
Bluest
A caliper spreader. The rewind tools are for floating calipers with a piston on one side only.
I did try a cheap caliper spreader once and it was a bit pants. It was as easy to use some wood and a pry bar. Maybe more expensive tools at better. If yours works post a link to it.
Be prepared for the pistons to be corroded/seized and not want to go back, in which case they'll need replacing or rebuilding. 2007 110 TDCi Station Wagon XS
Post #894317 27th Mar 2021 4:23pm
Clemmo
Ok Cheers
ordered off Amazon just to see. Ive always got by with the lever method too Embarassed
Any tips before I start to overcome stuck pistons?
Post #894318 27th Mar 2021 4:34pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
I use an old very warn (almost to the metal) break pad and a pry bar to push the pistons back.
Cheep and easy tool! Cheers Don.
Post #894319 27th Mar 2021 4:51pm
LR90XS2011
ditto use an old pad and pry bar,
one thing worth checking before you do it though is that the pistons are not corroded, pushing corroded pistons back into the seals will result in problems in the future, if not too corroded clean the exposed part of the pistons before pushing them back in.
second think is keep an eye on the fluid level, if it has been topped up pushing the pistons back can make it overflow. DEFENDER 90 TDCI XS,
Post #894334 27th Mar 2021 5:43pm
Ianh
I have a Neilsen CT0078 . Just do a web search for it and you will find they are £20. So not expensive for the correct tool.
Post #894344 27th Mar 2021 6:25pm
Clemmo
Job Done 😀
Pretty straight forward really.
Cleaned pistons with wire wool and some anti-corrosion spray.
Cheap tool worked a treat .........
https://www.amazon.co.uk/gp/product/B07D74...&psc=1
One piston was a little sticky but all good now.
Cheap enough with pads, pins and retaining springs £15.66 delivered. Eurocarparts.
Happy days
Clemmo👍 Make today a little better than yesterday but not so good as tomorrow....
Post #894789 29th Mar 2021 9:51pm
LR90XS2011
brilliant DEFENDER 90 TDCI XS,
Post #894842 30th Mar 2021 7:27am
Johan_B
Sweden 2008 Defender 110 Puma 2.4 CSW Tonga Green
I used one of those tools when attempting my fist ever brake pad change on my old 1998 90" in 2004. I got absolutely nowhere! After a day of despair (that included not being able to fit either new or old pads back in) I got the advise from an old mechanic that I should be able push the pistons back with my fingers or the very least with an adjustable plier. To achieve this, he said, take out the pads, push the pistons out a bit and then clean them thoroughly with an emery cloth all around. Works like a charm! Never had a problem since.
However, seeing that this method is not what people use, I just wonder if there is a drawback to it? To me it makes sense not to push back pistons that are not clean, won't they damage the seals? Once they are clean it shouldn't be a problem, or? (My experience is only based on 10 calipers so far so I might have been lucky.)
Post #1054943 17th Dec 2024 2:59pm
