Home > Technical > Oil leak help please
gerymor
United Kingdom 2005 Defender 110 Td5 SW Zermatt Silver
Hi can anyone help tell me what is causing this quite bad oil leak please. it appears to be coming from a short far pipe just above the front axle/diff, sort of next to the starter motor (I think it is that). Hopefully this photo will show it clearly enough. It’s not the thinner longer pipe on the left, it’s the short one on the right and you can see the oil wet all over the crinkly pipe. I can send more pics but I think it is clear if you expand this one. It leaves a bad mess on the drive every day. The engine oil level stays on the max line. 80k miles on a td5. Thanks.
Post #894313 27th Mar 2021 3:00pm
davidblythe
cant see with the photo. but is it the Fuel pressure requlator leaking diesel
looks the right area when it starts to fail 1999 90 TD5 CSW
2006 110 TD5 HD Commercial
Post #894314 27th Mar 2021 3:06pm
gerymor
Thanks David, that’s helpful, I hadn’t thought it might just be diesel. I’ll catch some in a tub overnight and give it the sniff test. I’ve expanded the pic and circled the pipe, looks like a breather of some kind.
Post #894323 27th Mar 2021 3:56pm
dorsetsmith
starter motor drains
Post #894325 27th Mar 2021 4:16pm
landy andy
The drip is on your starter motor. Directly above it is your fuel pressure regulator. These can develop a leak so that fuel runs down, washing your engine as it goes. It looks like oil but will smell of diesel. Test it for smell. If not the fuel pressure regulator it can be the gasket on the rocker top. (The very top engine cover) which is easily spotted once you get the acoustic cover off. If it is the rocker cover you will need a new gasket and whilst doing it I would also renew the injector loom whist you are there.
Fuel pressure regulator
Post #894342 27th Mar 2021 5:15pm
gerymor
...just to conclude this post, collected oil and no diesel smell, definitely gear oil of some sort. Now had it on ramp and there was a pin hole in the front diff casing. Sorted now and caught in time. Thanks for the input everyone.
Post #895781 3rd Apr 2021 6:37pm
